I purchased a t49f true commercial freezer used. After plugging it and leaving to run at my restaurant I noticed that once it gets down to temp the exterior thermometer starts to climb up in temp. After 5 or 6 minutes it shows the temp about 5 degrees above zero and starts the compressor. The inside temp is actually -5 when the compressor starts but the outside shows over zero. It keeps cycling like that, 5 minutes off and 10 to 15 minutes on.
I change the temp control and gaskets but it's still the same. I had 2 separate techs comes out and they couldn't figure it.
If anyone has any ideas why this is I would greatly appreciate their advice.
