Per a moderators suggestion, here is a thread about the same issue that dapper9030 is having on this thread.
http://hvac-talk.com/vbb/showthread.php?t=172834
Summed up[ my XL16I runs all the time, the house is 2067 under air and the Unit installed is 4 ton, the air handler is I believe a 3 and half ton Air Handler. But variable speed and is supposed to support the 4 ton compressor.
Model Numbers are as follows;
4TTX6048B1000A
4TEE3F40A1000A
I used to have a Janitrol that worked great, never had an issue with cooling.
Normally my thermostat is set to 79, during hot days this unit will climb as high as 83 and 84 degrees. Did I mention then unit is always running on high speed? This thing is sucking 75 Percent of my energy consumption, dollars and cents $280 per month Give or take 20 bucks.
HAs anyone found a solution for this problem? Any suggestion that have not been mentioned on the previous thread?
4TTX6048B1000A
4TEE3F40A1000A
