If they are Ipak (IntelliPak) units your in a whole new world of controls.
Exhaust fans on any of these? That is something to consider.
In essence economization really is not that hard, but apparently scares the living tarnation out of a lot of guys. If your dealing with Honeywell economization modules, be prepared to upgrade to the JADE platform since Honeywell has discontinued all the W7*** series modules and combined them all into the JADE. Will need new sensors, too.
At a minimum you will have the economization module, a temperature or enthalpy sensor taking in the outdoor information, a mixed air sensor in the blower compartment, and an actuator that is driving the dampers open and close.
A big thing many are confused about on Honeywell modules is the "N" terminal. This is usually tied directly back to the thermostat terminal board. It must have 24v to it for the economizer module to operate. Seen too many times an economizer is condemned since the tech did not realize that someone had either removed a jumper at the thermostat board or simply N was disengaged for some reason. The whole purpose for N is to be utilized with commercial thermostats wit the A or OCC terminals. Whn the building is in occupied mode at the thermostat the economizer will turn on and go to the minimum position setting for the dampers and wait for a call for cooling. In unoccupied mode the N terminal is de-energized and the dampers close 100% and economizer is in stand-by mode....just a word of wisdom.
If the module has Exhaust output, this is based on two things, the damper open percentage or IAQ needs. The exhaust fan(s) can be energized when the dampers open a certain amount. Or there may be CO or other air quality sensors, pressure transducers, etc that can be set to initiate the exhaust fan(s) when they reach a predetermined setting.
Half the time I find the economizer and exhaust fans were factory or field installed, but never commissioned. Just setting there virgin since day of install.......more common than you would think.
Push to get your PRO status, there is a lot of economizer info, literature, and troubleshooting guides in those forums. There use to be a very good YouTube vid on troubleshooting economization. It was being performed on a Carrier unit, but I believe it has been removed, searched for it a few weeks back and could not find it. Should have saved it.
