Hello all. Had a no cool call on a trane. 20i. 900 stat. Flashing fault led on condenser board. Every couple mins is hear a click and all lights go out for a few sec then come back. Found a lizard behind the board shorting the data term to 24 volt term. So I replaced the board and everything ran ok. A week later error codes start showing up randomly. And clear themselves. So the customer calls today with these codes. 126 89 90 91
And he said the unit won't run. I get there and there's only 126 and condensers not running. Also a weird issue is the cool disappeared from the system menu I pulled off the stat and made sure the three wires were tight. One was actually a little loose. So I put the stat on and there was the cool again. Now the system runs but 126 still flashing on stat. Is it possible the lizard caused a spike to the stat ? Any input would be appreciated.
