cg,
Concerning the receiver issue, what happens is there is a pick up tube that should tatke pure liquid out of the bottom of the receiver. Yes, there is a vapor and liquid mixture in the receiver, but the liquid will be on the bottom. You know, I just understood what you are saying- the refrigerant vapor and liquid are in cotact with one another so saturated discharge temp should be just that- not superheated OR subcooled. However, when you hav a reading of pressure on the liquid line and you are FULL of liquid in this line, you can read subcooling. I know what you are thinking, so look at it this way: If you had a refrigerant tank sitting in the shop, R22, and it was 90 degress, you would read a pressure on your gauge of 168 psig or so. This is considering that you had vapor AND liquid 22 in the bottle. Now, if you only had a pinch of gas in the bottle, well, you would read something less than that. Now, think of this, if you filled that bottle up totally with liquid, which we all know to be EXTREMELY dangerous, you would read a pressure that exceeds the ambient of that refrigerant, actually, you would be at some hydrostatic pressure. Now, I know it is a stretch, but I can only explain it in this way, well, because I am not too good at explaining things....lets try to imagine the liquid line along the same line of that tank full to the brim with liquid. You don't have the exceeding hydrostatic pressure because your receiver DOES have vapor on top, and you still have a gaseuos state in the condenser. Also, the longer the liquid line is, the more space you have to "cool" the liquid below that condensing temp that is occuring in the condenser/receiver. I have a feeling this post is going to get knocked around a bit, but I hope that I conveyed something. Good Luck.
r404a
