Always wondered:
Mode: AC, conventional 1 stage SEER 16 2 ton. [NOT Heat Pump]
S/P (TESP) let's say shows: 0.4
The furnace install document shows - for that furnace:
Switches (Assume please - CFM and on/off status since it's just an example)
x,y,z -> ON-ON-ON -> 800
x,y,z -> ON-OFF-ON -> 900
x,y,z -> ON-OFF-OFF -> 1000
x,y,z -> OFF-OFF-OFF -> 1200
[.... and so on and so forth]
I heard thumb-rule is 400 CFM / ton but that's thumb rule. Recently when my icing issue was fixed the blower speed he said is currently configured to run at max. He said he's not carrying the required meters to check SP but said probably the blower speed is good since you +40F VSTAT, 11.2 sub-cool (rated for 10F), and temp difference supply/return is at 22F.
