1 - 9 of 9 Posts
techdb
· Registered
Joined
Discussion starter · #1 ·
Hello,
I was wondering if someone has the plug-in for Staefa Predator VAV controller. And also have some hands on experience with the product. Your input is greatly appreciated. Thank you.
Best regards,
I worked for the local Staefa Dealer for 8 years, when I left they where just getting into AX and what I saw didn't work so well. In R2 it worked pretty well what issues are you having and what system is it on?
Discussion starter · #3 ·
Staefa VAV
Hi,
Thanks for getting back to me. Here is what I need to do, I have to demonstrate to a customer that a Staefa VAV controller can stay on the same network with a true LON open system controller and they both can be connected to a Tridium R2 panel. Do you have any installation PDF for this Staefa controller and I am not sure if I need to have the XIF file or the plug In for the controller or nor? Thanks for your help.
Best regards,
Ryan
Are you adding a new device to a Staefa System or adding the VAV to a differant system? Staefa does not have plug ins and to my knowlege they do not release .xif files. I did not know what an .xif file was untill I left my former employer. If its an existing Steafa System the .jar file should be up to date if not you may be in for a fun ride. Look for the shadow object in your library c/niagara/v5??/tridiumx/londevices/staefa the shadow objects are there .
All LonMark certified product xif's can be found on the LONmark site. Also there is a Plug-In for this device contact your local Staefa dealer for it.:)
Save
1 - 9 of 9 Posts
