My unit is up in the attic and I want to bring it down in the garage for a vertical configuration. My question is what size square duct made from duct board do I need? (3) return trunk lines 10,14,14
I wouldn't put it in a garage.It will soon be a new Goodman ASPF426016E 4 ton heat pump
A few questions from a non-pro...
1) Is this a DIY project?
2) Is duct board allowed to penetrate the wall into the garage?
3) Which is worse, furnace and ducts in attic, or furnace in garage and ducts in attic (and garage)?
4) Does manual J need to be redone for the entire duct system?
Your going to have some big code issues.
Railing protection system, has to be so high off the floor, has to be sealed EXTREMELY tight. Your just asking for problems.
But:
12x32 would meet the requirement for a 4-ton heat pump.
Unfortunetly for yourself, you've openly admitted your doing the ductwork.Any reason you wouldn't do 24x16? 24 being the depth of the unit.
Seems like having "sparky" do some duct is OK
Duct dimensions about 2 sq ft of area is ok for initial discharge. Main concern is getting the return sized ( 2 sq ft plus ) good and tight.
Choice of ductboard is really good choice since it is inherantly sealed when you use the UL 181 A tape
