Hello, I'm a home inspector and I check so many furnaces I decided to finally check my own. It was installed in Jan 2014 by a pro.
I was surprised to see significant rust on the primary heat exchanger. See pic. The rust continues inside the primary heat exchanger at the seams.
There is a humidifier attached but it hasn't run in a long time. The plenum steel shows no rust or marks from running water. The inside of the furnace cabinet has no rust or water signs.
The new power vent water heater (behind the furnace) had some spray, leaving some hard water stain on the back of the furnace cabinet, but thanks to aluminum tape there wasn't any that entered the furnace cabinet. And where the water contacted the furnace, it shows no rust either outside or inside the cabinet. The black iron piping in the furnace cabinet is not rusty. The exhaust-to-motor connection is not leaking.
The intake draws from the utility room and the fresh air intake is about 2 feet away.
Any thoughts/suggestions?
