Hi Folks- first time post. Hope its not too long. I recently completed construction of my personal home here in Minnesota. My choice for the furnace was as noted in the title here. It is 92.9 efficient modulating furnace with a Rodgers 1F95-1282 Programmable MultiStage t-stat. I paid someone to fabricate the plenum and set the furnace and I did rest. HVAC is not my forte and as such I think there might be some fine tuning needed on this. the fabricator sized the system and instructed me on trunk sizes etc. Its a clean install. I paid the fabricators service guy to adjust the air to air for me and also start it up. At that time it was cooling season. Well, when I started heating the A/C would trigger along with the heat. Not very efficient eh. So I went to the t-stat with the manual and four pages of programming and realized that it was programmed for a heat pump. I changed that and that fixed that. My concern now is the dip switches for the airflow. Rather than go through the whole deal, is there someone versed in this that can tell me how I should be setting the airflow switches? I am unsure which mode I should be operating in-single stage modulating or two stage? In two stage, first stage 40% of capacity always and then 2nd stage, phase one zero to five minutes 65%/2nd stage phase two after five minutes 100% ? Or should I be operating in single stage modulating? Lots of other settings depending on rise rates and that, but basically- where is a good start in your terms to set this thing. Just seems like with the extreme insulating I did, (closed cell) that it is costing too much to heat. My first guess is that the fan speed is not great enough, even keeping it on all the time as the air to air exchanger instructions suggest, there still seems to be a problem getting heat to the farther runs.
I want to add that i have a great appreciation for your trade. i did this myself with verbal guidance from the fabricator, (older guy that has been doing it for ages and I think the technology has gotten away from him) and it was tough work. I learned some tricks along the way with his input, but honestly, I will never hang trunks like that alone again! Lastly- the system has three zones with manual dampers and I have played around with those as well as the dampers ahead of the registers at every run.
Thanks in advance- Joe
