Rosebud tips for MC/R
1 reading
5.4K views 7 replies 4 participants last post by  Greend88
#1 ·
So I have a Uniweld MC & R tank oxy/actylene set, and being a commercial tech, often find myself brazing 2" plus copper. I've had the Uniweld 17-15 rosebud for several years, but almost from the get-go and particularly the past two years, I've had issues with the rosebud tip in particular. Occasionally it would work great, but on jobs where several joints were made, it would start to sputter and act up, and the blue section (acetylene) of the flame would impinge and sputter, and the tip would get hot as hell, causing the O-rings to wear quick and the tip and handle to need a cleaning. During down time, I would disassemble, clean, and replace the o-rings, it would somewhat work for a while, and then the cycle would repeat. A couple days ago, I was on a job where I had to work quickly on 3" copper, and of course, the tip started acting up and actually got plugged. I said "F this" and immediately ordered a new tip and handle, this time going to the 17-30 rosebud -- same price, but can braze bigger pipe. I just got the tip, and I noticed that it says on the packaging "for use with B acetylene tank or larger," and I wonder if this has been my problem all along. I would keep my MC & R pressure regulators set to 10 and 20, respectively, and use the handle to tweak. I did notice issues when the tanks got low that the regulators would have trouble keeping up, but have any of you guys experienced the tip burning issue? Do any of you use rosebuds with the MC acetylene tanks and have trouble?
#2 ·
MC does does not flow enough for reliable rose bud operation.
I also have had problems with uniweld rose buds no mater what the setup. W-200 prestolite purox handle and #15 and #30 tips have proved most reliable and economic set up for us, and we braze alot, supermarket installs.
#4 ·
Think it has to do with the hoses. I had the same issue with my MC/R setup and the 17-15 rosebud tip.
The hoses that come with it are not 3/8.
Used cutting torch with bigger hoses on a small mc and made 3 cuts out of 8" ibeams with no issues
#5 ·
Cutting is O2 rich, rose bud is a problem because mc is tank is 10 cf and should not flow more 1cfh intermittant. #15 tip probably flows 10cfh. So you run risk of pulling acetone out of mc, leaning of flame, and flame retreatining into tip.
Cold weather, long hoses, beat up dirty regulators with clogged filters only make problem worse.
Yes, we get away with it often but it's against CGA reccomendations and acytelyene makes a loud bang.
#6 ·
It makes sense that I never had problems with the cutting tip, since, as you say, it's O2 rich. So for the rosebud, do you think my idea of using an adapter for a B tank will work? It adapts a B tank to my MC regulator, and I would still use my R tank, of course. I know this #30 tip will probably require even more flow, and I know from past experience that the #15 tip had moments that worried me, to be sure.
