New member here, and thank you in advance for any help.
I have a few stripes over at ContractorTalk.com So if I can return any advice let me know.
Heres the deal. Installed new Rheem RGGD with a/c (no heat pump) fully modulating with RHC-TST401MDMS, in my own home, and something doesnt seem quite right.
1. RHC-TST401MDMS Thermostat doesnt read temp in real time..my digital thermometer raises 3-4-5 degrees before the Modulating t-stat raises 1 degree. It seems it takes about 30 minutes before the touchscreen t-stat catches up...Is this normal??
2. can someone verify the wiring for me? On the tstat I have B, O, Y2, Y, G, RC, RH, C, W2, W/E, 6, V
on the furnace I have W, V/W2, Y1, Y/Y2, G, C, R,
Am I supposed to put a jumper between W/2 and W/E on the tstat? If I dont have it there the heat only comes on in +2 mode..????
Otherwise I have (furnace 1st) W to W/2(with said jumper), V/W2 to V, Y1 to Y, Y/Y2 to Y2, G to G, C to C, R to RC (jumped to RH),
The guy I hired to do this install turned out to be a flake, so Im on my own at this point...
Sorry for the long winded Post but I sure could use some help here...Thanks
