1 - 1 of 20 Posts
Does that mean you'll be removing the top/fan assembly to clean the inside of the coil now, or to pull the clumps of lint when washing/cleaning from the outside of the coil.
Gives new meaning when referring to the inlet side of coil now...
Possible now with the cooler ambient air going across the fan motor body it's keeping the internal overload from tripping...whereas before, the rejected heat from the condensor was being pulled across the fan motor body.
If a dog urinates on the coil now when it's running does the urine splash back on the dogs face?
Helps keeps the compressor surface temperature a little cooler now ( if compressor is in the path of the cooler air ) :whistle:
Save
1 - 1 of 20 Posts
