Our AC has not been cooling well. Technician came out today and said it was practically out of Freon (R22) most likely had a leak and would cost $ just to add coolant. He got the compressor running for now, did not check for a leak/leak location. Recommendation was to get a new unit (inside and outside). Outside unit is from 2003 and no idea on age of inside coil. The drain pan on inside coil has a leak but we have worked that out with a bit of shimming and unit has worked fine since, till now.
So is it even worth considering fixing this system and if so is there an alternative to R22 that could be used? Is it just time to bite the bullet and get a new one?
