replace a 5uf capacitor with a 7.5mfd ok?
83K views 8 replies 8 participants last post by  vstech
#1 ·
hello all,
i had an hvac company over today and the tech replaced the 5uf capacitor with a 7.5mfd on my very old inwall furnace. he stated that the higher capacity didnt matter and that if anything, it would help the blower run better. just wanted to confirm if what he did was ok or if he just didnt have the matching capacitor in his van and just stuck this one in to get it working.
thanks!
#2 ·
He is incorrect. It will not make it 'run better'. If anything, it will run less efficiently but the difference will likely be negligible. The main concern is that when this 7.5 fails and the next guy comes and says 'well, i don't have a 7.5 but i have a 10. close enough.' the issue can be compounded. I think that if you already paid for the 7.5 you probably wont have any issues, even though it is technically wrong. I might get yelled at for saying this but i would just let it go. good luck.
#3 ·
well, if it doesnt blow anything up, i guess i'm fine with it. he did leave the original capacitor, so i'll just keep that near the furnace in case it happens again. btw, is uf and mfd the same thing?
thanks for the answer ADillon
#9 ·
it's not Uf, it's the greek symbol for micro... looks very similar to a u but it's an µ
and yes, µf means microfarad
motor capacitance determines the shift for motor torque, and the field is wound for a specific value. +/- 10% I think... so if it calls for a 5, it needs a 5 MAYBE a strong 5 would work, but a 7.5 will cook the motor in short order.
