We purchased a home with this RGF Halo-LED already installed on the older furnace (The sticker they put on says Feb2023) - it is wired through a pressure switch and then through the REME 24 VAC XFMR. I noticed that the light on the HALO unit was off. We were already having some one come out to look over the system so we a ballpark of what to expect. He looked at the Reme HALO LED and found the XFMR had 0 volts on the secondary. Furnace is 120 - XFMR is 24 VAC 40 VMa. He replaced with a xmfr that identical specs. Pressure switch works, can see the light turn on. While he was here the xfmr went hot and failed. REME isn't very helpful, they keep assuming we are asking for warranty.
I'm just looking to know if this is a known issue with them, I've done some reasearch and I know there are concerns with ionization etc. but it was in the system and I figured might as well get it to work.
In my line of work an overheated xfmr means there are problems with the load side or the the unit is really underrated.
