Hello, sorry for the long winded reply. I tried to be thorough and hopefully it makes sense. I highlighted the conclusions. I tested the REME LED, plus then a ventilating dehumidifier after that. I hadn't found any data whatsoever from a real home about the REME LED so I decided to get one and test it. It is wired via a relay to turn on any time the air handler turns on. For testing I have a new 2,000 sq ft home with a two stage Lennox heat pump, variable air handler, and merv 13 5" thick healthy climate filter and returns throughout the house. The REME was installed in the supply plenum. The contractor swore up and down how much it does for people.
I have been using a Kaiterra Laser Egg +VOC to get general trends for VOC's in our home. Calibrating it has quirks. Prior to the test I used it for like a month to get used to it and get consistent readings. It really has to be turned off for a long time like a day. Then, you turn it on outdoors and let it calibrate for at least 5 minutes. This works every time.
Prior to installing the REME, our particulate count has always been near zero. 0-45 ppb total particles and always 0 PM2.5. So, as noted you won't see a particulate change since it is already basically nill. It claims to use positive and negative ionization to make particles stick together to make lower merv filters work better.
Prior to the test, our TVOC levels were higher than acceptable usually 550ppb. They would stick around in that area of 525-575 plus a bit depending on what we were doing. Open windows to air it out and it would go right back there.
I got the REME LED installed. I ran the air handler a lot for two weeks. I usually run it at 20min/hr during mild times to keep the air filtered. This test was during the mild Florida winter. I tried the fan 20min/hr and I tried running the air handler 100% of the time for a couple days also (which isn't practical anyway). I saw absolutely no reduction in VOC's with the REME LED. There was no change over a two week period. It was for sure working because you could smell that sweet smell where the air leaked out around the REME. I noticed no smell from the REME LED in the house. I have concluded that it has zero benefit that I can measure for my particular home. I know UV light sanitizes, but I don't have a way to measure that, plus, it doesn't seem necessary anyway. Usually trying to sanitize everything as we know from science can create super bugs that escape through the sanitization process.
Way prior to this I had a whole house ventilating dehumidifier on order for our home (it wasn't installed yet). Once they finally installed it since it was backordered, well that 25-30cfm of constant positive pressure ventilation made a huge difference. I found leaving the fan run on the dehumidifier works best to have a constant trickle of fresh air. The air comes in from outside through a 4" duct and damper and meets up with recirculated air in a mixing box which then goes into the dehumidifier. The contractor said this was to prevent hot humid air from hitting the cold coil unevenly and also to hopefully prevent growth which they need to inspect yearly. It is a Trane Envirowise they used, but it looks like a Sante Fe Ultra 70 rebranded. Our VOC levels are now usually around 190ppb. I see on a typical day 160-230ppb. It goes up a little when we are home and down a little at night or when we are not home. From my understanding we are now in the safe area. Our particulate count went up a tiny bit to around 100ppb at times, but is usually 50-100 which is still very low. If the air conditioner is running more, it drops the particulates down near zero. PM2.5 remained 0 throughout all tests. The Merv 11 filter on the dehum allows some more particles through the ventilation it seems. The dehumidifier will pull humidity down to whatever you set it at even while mixing in 100% saturated air we have at night. We like it at 50%. Pretty neat.
After this I have tried turning the REME LED back on for days here and there and it seems to make us stuffy and snore. Maybe the aerosolized hydro-peroxides affect our noses? Seems to be an interesting observation, but too many variables to know for certain.
I have tested another great thing which was a DIY project. This didn't interfere with the test. This was after. I sealed the garage/house barrier wall as best I could and installed a 4" exhaust duct with DC in-line duct fan. The garage was so well sealed actually that I then installed an 8" passive inlet duct with bug screen grill jumper from soffit to garage. I noticed a drop in VOC's inside the home especially when charging the golf cart which would cause a drastic spike of well over 1000ppb sometimes reaching 1500ppb! Golf cart battery equalization lets off hydrogen sulfide. It now does not affect the house air. It's nice to know we can now use the garage for it's intended purpose without polluting the inside of the house.
In conclusion: What a learning experience! The REME LED doesn't work for my needs. I have found ventilation works very well to reduce VOC's! I found in my new home I want garage isolation from interior air with exhaust fan, plus a ventilating dehumidifier for the interior space.
