Rectorseal 5 vs T plus 2
1 reading
49K views 15 replies 12 participants last post by  jmac00
#1 ·
Tried google and asking several plumbers but couldn't find any real difference. They both seem to cover mostly the same pipes, they are both able to be instantly pressurized. So what's the actual difference and when would you use one over the other? Does one seal better? Needed some the other day for a potable water threaded fitting and the guy at lowes said "uhhhh use the t plus 2" but couldn't explain why to use that one lol. From reading threads on here it looks like lots of guys use the rectorseal 5
Save
#2 ·
It is all preference. And Lowe's. Why on earth would you expect to get a gram of knowledgeable advice from their employees. I swear they only hire those that have no clue of their products. Irt sucks, that my wife has more knowledge of their products and their proper use.
Than their workers. She has also helped a few handy hacks that were trying to install a water heater. The employee was trying to talk them to use ferncos on the two inch supply pipe. After several minutes of sisde splitting laughter. She went over to the next aisle and asks what they were frying to do. They explained. She called them idiots. Told the employee to go look cute some where else, and while doing it grab a repair book sitting by the plumbing desk, and read it. If they are able to read. She was able to give the sorry are hacks some sound ad ice and help them pick out the materials .
The manger witnessed all of this. He suggested my wife apply for a job there. She did. Had her interview. Only to get an email saying she wasn't qualified enough to work on the plumbing department. Well I wonder how the idiot of that day got the job?
#5 ·
Teflon tape and megalock (Thats a good one ask the lowes guy) ... you know how much incorrect advice i have be given over the years fro box stores/hardware stores not knowing i was a plumber. 1 time even had a 18 year old kid tell how to do it (All wrong) and i explained i'm a lic union trained plumber, and while walking away, He say's ok, but your doing it wrong. Now i just let them talk to see what weird way they would do it.
#6 ·
Rectorseal #5 is the gold standard. It's what your great grandpa used before electric pipe machines were invented. T+2 is pretty much the same thing, except it has this fancy new ingredient in it that they call Teflon. The T+2 also seems to be less messy and it stains less when you get it on your clothes. There is also Rectorseal #100, which is just like T+2, only it's more expensive. That's the kind I like to use when I'm mad at my boss about something. :grin2:
Save
#7 ·
So basically Rectorseal 5 is the way to go every time? I didn't ask the Lowes guy, he saw me looking at them and said can I help you with anything? I said sure, whats the difference in the two? Pleasants hardware seems to be the worst. One time I asked where the wire staples are.... "huh? whats a wire staple? Why would you want to staple a wire?" Then today I asked where the nail plates are... "..... I dont know what that is, what is it used for....." LOL.
So there is no real difference except rectorseal 5 is the old, time tested formula and t plus 2 is a fancy new formula?
Save
#11 ·
Well... If you compare the two dopes on rectorseals website...... there are some slight pressure differences.... tp2 never sets up while 5 is slow setting..... and rectorseal 5 is not recommended for abs or cpvc pipe.... might be some more differences but thats all I saw...
Looks like the abs and cpvc pipe thing is the biggest diff.....
Save
#12 ·
Yeah I saw those couple differences but I think your on to something with the set up. That must be it. Talked to some plumbers yesterday and got some more pipe dope info so apparently:
T plus 2 - never sets up
5 - soft set
Leak lock - hard set
Expando - never get it apart set
Save
#14 ·
I've mostly has rectorseal on the van/truck for years. does gas, steam, water, oil, which pretty much covers everthing I do. otherwise, teflon tape on plastic- drain pans, etc.
I've seen some olive green stuff on 50s pipes before, permanent.
Save
