I recently switched an air cooled chiller (trane) that I had to replaced R22 with R438a. Both circuits only had 30-40 psi standing pressure. I repaired all the leaks found. Pressure tested and pulled a vacuum to 400 microns overnight. Pushed in the R438a (liquid) to 150lbs (total 170lbs). I charged the rest while running. I've got 3 compressor's each circuit. 1- 10 ton 2- 15 ton. After 5 mins of run time the 4 large compressor's(2 each circuit) are pulling LRA @ 164 amps. The smaller compressor's for each circuit is running fine. Each circuit is in Tandem with 3 compressor's. My Question is has anyone had any problems with the R438A with compressor's over 15 ton's.
