Pulley and Sheave: Difference
Ever Power
Ever Power
Dec 6, 2019·3 min read
Pulleys have been used by mankind from time immemorial. They are used to make lifting heavy objects easier. A pulley allows a person to lift a particular load with less effort than what would have been required without a pulley. They are typically made with ropes and wheels. The term pulley is interchangeably used with the word sheave. This is not correct as they are different things. Here are the differences between a sheave and a pulley:-
The basic difference — A pulley is one of the six types of simple machines that have been used for humans for a long time. It is a basic mechanism. The sheave that is pronounced as shiv is part of the pulley. It is the wheel with grooves where the rope fits in to.
Complimentary — Pulley without a sheave changes the direction of the pull to lift the load but it doesn’t change the force or energy required to lift the object. By adding multiple sheaves we get a mechanical benefit as it reduces the energy or force required to lift a particular object. The force required reduces in half with each sheave you add to the rope but this cannot be done indefinitely as the utility with each sheave decreases till its negative.
Problem — Though adding multiple sheaves reduces efforts, but it can also cause fiction. You cannot add an unlimited amount of sheaves as after a few the force required will start increasing with each added sheave, due to the friction caused by them. This increase in sheaves and ropes will make your work harder rather than easier. The solution to this is a compound pulley where the sheaves are added above and below each other and supported by an axle. This will increase the efficiency of your pulley by adding more sheaves.
Simplicity — Maximum work can be done by attaching a single sheave to a rope. There are certain things to keep in mind while doing this. Firstly, the surface area of the sheave should be at the possible minimum to the rope attached. Secondly, the sheave needs to be abrasion-free. Lastly, the sheave must not be prone to warping. If these three things are kept in mind while making a pulley, your device should do its job without glitches or additional problems related to the same.
Expert opinion — according to engineers who have worked with pulleys for a long time, the differences can lie in context. Pulleys and sheaves can mean different things depending on the industry you ply your trade-in. Another common answer that we got from experts is a
sheave is mostly used as the name for a drive pulley. It can also depend on the area of the world you are staying like in Some parts of the united states where sheave is used as a substitute for a pulley. Another response that we got while asking for differences is that
Sheave Pulley is a heavier duty pulley. Most experts though agree that there is no difference between a sheave and a pulley. The difference arises when you go into further details and they are also few and far in the middle.
Etymology — the word pulley has been in use in the English dictionary since the early 1000 A.D. Before that the word for pulley in greek was polos which were used as far back as 400A.D. Whereas, pulleys have been used from around 200 B.C. the history of the pulley is long and the story of its name is incomplete. Sheave is an even older name than a pulley and can be traced back to the proto-germanic language where a Scheibe means a disc or a bundle. The history of the sheave is unfortunately not clear except its maybe origins.
Dictionary — It’s always good to check the dictionary to check the meaning and difference between two things. According to the dictionary, a pulley means “a wheel on an axle or shaft” and a sheave means “ a pulley with a grooved wheel”. Therefore, it means that pulley with grooved wheels is sheave and all others are pulleys.
There is not much difference between a sheave and a pulley. You may say that a sheave is a particular type of heavy-duty pulley and it is a part of the pulley. The difference lie is details of use and location but for the amateur user, there is a negligible amount of difference. These sheave pulleys are available around the world and in different qualities and sizes for suiting your work. To know more about sheaves and pulleys, please visit
https://www.ever-power.net/pulley.
