I'm new(er) to the industry. Been doin AC for a few months and I try my best. However, I need some advice on pressure testing as I'm not 100% confident with my gauges performing up to par yet. I have testo 557's and they seem to be pretty good so far (beside the knob feel and placement sucks). I do pressure tests with nitrogen after I perform purge brazing and every single time I do the test I seen to lose about 1-3psi after 20-30 minutes.. Is this normal? I know the system should be leak free but I just want to see if this variance is normal with digital gauges.. In school we used manual gauges and its hard to tell if it moves 1 or 2 psi.. Could this be a hose issue? Keep in mind the setup is fairly new (new yellow jacket hoses too) but they were sitting for a year in my room in a box before I used them.
Vac tests all hold under 1000 microns. There is a initial jump but then 5 micron increases every few minutes but then slows right down.
