Currently living in a 2100 sq ft double wide. A york system was installed five years ago. It has since died. I have been told the problem was due to the inside unit being one for a stick built and not a mobile home. With that being said I have had three different contractors come out. They all agreed the inside unit needed to be one for a mobile home due to the duct work and something about static and working too hard.
The first contractor gave me a quote for a 3.5 ton lennox system.
The second contractor stated based on square footage I should be using a 4 ton unit and price a trane system.
The third contractor came out and said that the only unit that could properly be installed was a goodman because they were the only ones who matched the inside unit (coleman) with the outside one. And that a 3.5 ton would be fine.
I am at a loss. I really have no idea about any of this. I have tried researching as much as possible but I'm really not having much luck in regards to NC statues (the third contractor said look up 302.1 but that doesn't pull anything up in regards to the issue at hand). This is something my husband would normally take care of but unfortunately he passed away unexpectantly last December.
So is the third contractor correct in that mobile homes require certain inside units in order for them to match the outside unit. The first two contractors never said anything about it, nor did they mention the type of inside unit they would be installing in their quotes, one sates standard air handler, and the other single stage whatever that means.
Any advice would be greatly appreciated. The current unit is only five years hold and shouldn't even need to be replaced and I don't want to make a poor uneducated decision and be stuck doing this again in another five years
Thanks in advance!
Thanks in advance!
