Our new HVAC system has a 2 stage 96% nominal efficiency gas furnace and I am concerned that our standard overnight setback temperature is set too low. We keep the thermostat at 70 during the day for heating, and have, in the past with a 1 stage gas furnace, set the overnight temperature to 60F. With the new furnace a 60F setback temperature and outside temperatures of 35-40F causes stage 2 heating to kick in shortly after the furnace turns on in the morning and stay on until 70F is reached. As I understand it, though, stage 2 heating is less efficient than stage 1. If I set a higher overnight temperature (say 66F) the furnace will operate in stage 1 just about the whole morning heating time (at the current outside temperatures).
I've read similar threads to this about heat pump systems where the recommendation is to raise the overnight setpoint to avoid triggering auxiliary heat strips. But I think that situation represents a larger difference in heating efficiency than the 2 stages of a gas furnace. So I'm not sure about what setback to use. Is the efficiency difference between stage 1 and stage 2 heating of a 96% gas furnace large enough to limit our overnight setback to a temperature above 60F (say 66F)?
If it makes a difference, the furnace is a Luxaire LX series.
