When Trying to discover points from my jace into my supervisor im getting the following error:
When I ping the jace from the super It says connected but after 10 mins or so disconnects
Any ideas?
com.tridium.fox.session.ServerException: java.io.EOFException
at com.tridium.fox.sys.LocalizableExceptionTranslator.messageToException(LocalizableExceptionTranslator.java:102)
at com.tridium.nd.point.BPointChannel.discover(BPointChannel.java:887)
at com.tridium.nd.ui.NiagaraLearn.bqlDiscover(NiagaraLearn.java:168)
at com.tridium.nd.ui.BNiagaraPointManager$Controller.doDiscover(BNiagaraPointManager.java:788)
at javax.baja.workbench.mgr.MgrController$Discover.doInvoke(MgrController.java:872)
at javax.baja.ui.Command.doInvoke(Command.java:311)
at javax.baja.ui.Command.invoke(Command.java:281)
at javax.baja.ui.BButton.doInvokeAction(BButton.java:149)
at javax.baja.ui.BAbstractButton.mouseReleased(BAbstractButton.java:554)
at javax.baja.ui.BWidget.fireMouseEvent(BWidget.java:1228)
at com.tridium.ui.awt.MouseManager.fire(MouseManager.java:325)
at com.tridium.ui.awt.MouseManager.fire(MouseManager.java:299)
at com.tridium.ui.awt.MouseManager.released(MouseManager.java:131)
at com.tridium.ui.awt.MouseManager.process(MouseManager.java:104)
at com.tridium.ui.awt.AwtShellManager.processMouseEvent(AwtShellManager.java:509)
at com.tridium.ui.swing.BSwingWidget$GlassMouseListener.redispatchMouseEvent(BSwingWidget.java:641)
at com.tridium.ui.swing.BSwingWidget$GlassMouseListener.mouseReleased(BSwingWidget.java:510)
at java.awt.Component.processMouseEvent(Component.java:6539)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3318)
Any ideas?
