I have a 3350-sf house in the Memphis area w/ 2060 sf on 1st floor and about 1300 sf up. Have decided to replace both 19-year-old systems w/ Goodman. (Downstairs unit bit the dust last fall so we're just going to replace everything.) I've researched other brands and have decided based on better warranty, testimonies of people I know personally who have gone w/ Goodman and those who service them, that I can get more for my $ w/ Goodman.
The current 4-ton downstairs A/C was never able to keep up when it exceeded 80 degrees outside. A manual J done last year calculated 4.5 tons down (high ceilings, a lot of unshaded southern and western exposure), but of course they don't make that size. Installer is going to enlarge some ductwork (which will currently handle 4.5 tons) and returns to handle 5 tons. Going from 2.5 tons to 3 tons upstairs since the manual J indicated about 2.75 and the ductwork will handle 3.
I'm working with a reputable HVAC company and fully understand that a good installation is 99% of the job which I'm satisfied they will do -- they've been in business over 50 years, good BBB ratings, weren't the lowball bidder, and put sufficient time into evaluating exactly what we need, but Goodman isn't their "premier" brand so I wanted to do some research on my own. After all, this is a very big investment, and I want to get it right so I ask a lot of questions and "trust but verify" just for my own peace of mind.
We live downstairs virtually all the time and like it cold in the summer. Keeping air circulating and humidity (and utility costs) down are the important considerations. We don't keep it too warm in the winter.
Because all the larger Goodman 95% furnaces are 24.5 inches wide and therefore will not fit through the attic stairway (even if it were to be torn out), we're having to go with the 80% units. Since we pay only a few hundred $ a year on gas for heating, I've calculated the savings between the 95% and 80% would be very little, and we'd already decided to go with the 80% upstairs anyway. Our real utility savings should be on electricity in the summer.
Here are the combinations I'm considering.
DOWNSTAIRS: DSXC16 (2-stage) + GMVC8 (VS, 80%)
I'm pretty sure of the downstairs system. The only option would be to go with the 18 SEER (DSXC18) which makes about 8% difference in the cost of the whole house system. (I don't think I'm breaking any rules by saying that.) So I think the only question I have to consider is, assuming plugging other sources of energy loss (insulation, weatherstripping etc.), would the 18 SEER give enough energy savings to recoup the price difference in a few years? I'm thinking not since we're paying around $1000-1200 a year on cooling now (about 8.5-8.8 cents/kwh) and that's with only an 8 or 9 SEER system (and a 19-year-old one at that). Just going to a new 2-stage, 16 SEER unit should take a chunk out of that.
I installed touch-screen programmable thermostats 4 years ago (I don't program them, they're just a lot easier to read and look very cool
) but I wasn't planning to replace them w/ the Goodman ComfortNet thermostats which would involve running extra wiring. According to the installer, new thermostats would not result in any energy savings. Are there any other advantages of installing the ComfortNet thermostats besides just being able to see more information (diagnostics, etc.)? Are they necessary to get the full benefit of the 2-stage, VS system? (I've gotten conflicting answers to this.)
As for the furnace, the manual J done last year indicated around 95-100,000 BTUs. This installer seems to think 90,000 is enough. He's going to do his own manual J which may provide a more exact number, but if it still comes out about the same (say, 100,000), would the 115,000 BTU be overkill? (Those are the choices w/ Goodman -- 90,000 or 115,000.) Not sure what sizes we have now, but even though we don't keep it too hot in the winter, there are some very cold areas, particularly on the shaded, north side of the house which is at the far end of the duct run.
UPSTAIRS:
Several things to consider here which is where I'm conflicted and need advice.
Can't decide if 13 (GSX13), 14 (SSX14), or 16 SEER (SSX16) along with the GMH8 furnace is the way to go or if the 16 SEER 2-stage (DSXC16) w/ the VS furnace would provide enough of an improvement in temperature stability and humidity control to make it worth the extra $. Just going from 2.5 tons to 3 should make some difference as will going to even a 13 SEER, but trying to decide if the 2-stage compressor w/ VS blower, even though we don't live upstairs that much, would help even out the whole house by providing a better "buffer" between the roof and the downstairs.
The manual J indicated a 60-70,000 BTU furnace upstairs which makes me think the 90,000 downstairs sounds a bit small in comparison.
One last question about the upstairs furnace. Does the GME8 (w/ the XE13 motor) really provide much in the way of energy savings over the standard motor in the GMH8? Installer says his Goodman distributor doesn't stock the GME8.
Sorry to be so long-winded. Any practical advice would be much appreciated.
UPSTAIRS:
