1 - 3 of 16 Posts
You did all that work in the basement and it's still a swamp.
I would be VERY curious to know where all that moisture is coming from, and if it can be controlled.
Aside from that I agree with teddy bear. You need a dehumidifier in that space to run 24/7, as you don't have much cooling load down there for a mini-split or other form of a/c to make a difference.
Save
The dehumidifier will circulate air, and dehumidify it simultaneously.
Basements stay cooler than the rest of the house largely because their walls and floors are below grade. In your case, you added stud walls, insulated the cavities, and added a vapor barrier. I'm curious as to where you put the vapor barrier, but most likely you attached it to the stud faces and then drywalled over the studs and vapor barrier. With this arrangement I hope your Thoroughseal on the cinder block really does prevent moisture migration through the block. Otherwise you'll trap moisture between the cinder blocks and the vapor barrier, creating a mold farm.
TB is correct to call attention to moisture infiltration via outdoor air. The unfortunate aspects about most home basements is that they exist in humid climates, whether the climate is hot/humid or mixed/humid. Does your basement have windows where the walls emerge above the ground? Are these windows older than the hills?
Your basement floor...I take it you left it as is. No insulation, no vapor barrier. Is it a finished floor?
Save
1 - 3 of 16 Posts
