My system in the attic has the primary drain with no clean out access port on the drain and a float switch in the secondary port.
I am wondering if I can pour vinegar periodically ( to keep the line clean ) through the secondary port after removing the float switch temporarily, as vinegar will eventually drain into the primary drain line after transiting through air handler drain pan ?
Is vinegar safe to transit through air handler drain pan ?
It it necessary to flush vinegar by pouring water into the port after letting it sit there for some time ?
The system is a downflow furnace/ac and the air handler is under positive pressure with no p-trap in the primary drain line .
Thanks.
Thanks.
