I have this customer who should play the lottery with his luck.
In August I changed the module on his ecm blower motor, today I replaced both the motor and module of the blower due to a more catastrophic failure of the motor.
I install the new blower motor, turn it on and walk out to find the condenser fan (variable speed also) isn't spinning. Here's the kicker, if I disconnected the compressor from the circuit and turned power back on the fan would come on but operate erratically, ramping up and down in speed. I don't have an oscilloscope, but I saw no obvious drop in voltage when I turned the unit on with the compressor in the circuit
After a few more times connecting and disconnecting the compressor, the fan just wouldn't start up anymore. Told customer he may need to look into getting the power company to monitor the electricity to his house after having this many ECM motor failures in a short period of time.
Anybody else have customers with similar problems? I could buy undersized ductwork as the cause of failure for the blower, sure, but to have the condenser fan fail at the same time is a little fishy to me.
