First thing.
There is a lot more info in the Pro section. I have two articles in the Educational Forums that you can benefit from. The Educational Forums are unlocked to Pro members, and our threads go into much more detail than in the open forums.
Look at the very bottom of my posts. See the blue letters that say, "How to become a professional member"?
That's a link. Click on it and apply now. You already have the necessary 15 posts.
You mentioned the L2 fuse. I have to assume it is in a disconnect. Is this a single phase motor (two fuses) or a three phase motor (three fuses)?
What is the amperage value of the fuse(s)?
What is the code designation on the fuse? Is is a "NON-15"? Is it a FRS-R-15?
Is there a voltage drop from the load side of the disconnect and the line side of each phase?
If any of these questions sound like Greek to you, I would start like this:
Have your lead technician or a highly experienced friend look at this issue with you, and show you and ask you about the relevant ideas in play here.
Do an online search for "Fasco Facts." Download the pdf and read all of it.
Current in an AC motor is a function of two main factors:
1) load, the force the motor is being asked to overcome, and
2) rotor RPM.
These are related ideas. As rotor RPM slows, there is less opposition to current flow by counter electromotive force. When a motor first starts, rotor RPM is zero, and the only initial opposition to current flow is conductor resistance. Then, there is an immediate counter EMF which begins to oppose that initial flow. Then, as the rotor begins to turn, even more counter EMF is developed until current is limited by full rotor RPM and the amount of load.
LRA is usually about 6 times the FLA on the nameplate. It is the instantaneous initial current when the coils are first energized.
So, if you can give me a little more info about this unit (the questions I have already asked, for example) we can create a series of steps that you and your lead tech can follow.
