Has anybody every done this? I just installed my first very minisplit in my personal home about a month ago and it wasn't too difficult so this next project peaks my curiousity. My current problem is that I have a restaurant that's panera bread style that uses 2 flattop grills, a bread oven, 2 massive green egg grills. There is 2 massive exhaust hoods, one is pulling hot air out so that's good and another is pulling cold air out because it's pulling too much ( I can slow it down but I'm not at that step yet and yes I understand the positive / negative airflow would be slightly off).
The store currently uses five 5 tons gas packs, 3 in the serving area and 2 in the back. The rear 5 ton is serving the non-kitchen back area of store (washing, cooler, office). The kitchen 5 ton is split between a hallway and the kitchen itself so I'm guessing the kitchen itself is only getting 2.5 tons tops. The ceilings are about 10 ft high so you can barely feel the cool air.
The main concern with management is that the true dressers are holding the food at 60 degrees on the surface ( the inside is holding 40-45 but they have these things packed massively), I personally feel bad for the employees. This is located in South Carolina so it's hot!!!
Unfortunately I am a 1-2 man crew so I don't have the capacity to install a new RTU in the roof and rerouting duct work isn't an option as it would steal air from other spaces. 4 thermostats read 70-72's where the kitchen is 81-82. Given my situation, is installing 2 individual minisplit heads a plausible idea? I'm torn between two 1 Ton heads vs two 2 heads? I'm thinking probably with two 2 ton's. And sorry to disappoint, I'm only 23 so I haven't gotten to load calculations in my career yet. I've looked into the ceiling tile style ventilators but I personally believe the ceiling is too high to make any real difference to the food or employees.
Someone also told me that Dhec may not allow it, is that true or is this more of a myth? There are no fryers around so grease isn't a problem and the drain will be properly drained away with pvc or copper.
Units are Daikin FTK12NMVJU / RK12NMVJU (EVAP/COND) 1 TON
OR Daikin FTK24NMVJU / RK24NMVJU 2 TON.
United Refrigeration do not carry Mitsubishi or Fuji (whatever that brand is) ( I do have the catalog so if you have any other models, I can look at it)
Please advice and thanks in advance
