This is a picture of the schrader valve cap and also caps over the valve adjustment on a mini split.
What is exactly the purpose? Is it just to protect the schrader and the valve adjustment, or is it used to seal in the refrigerant if there is a leak?
If it is used to seal in the refrigerant, do you need to use something like nylog blue on the threads to make sure the cap seals? I just don't see this cap sealing in refrigerant when there is no rubber seal on it.
