Have any of you ever had a intermittant problems with the bin switch itself?
Causing 3.5 minute harvest errors. A month or a couple weeks apart.
I have fad a couple bin switches do this. Never seems to happen when your there. Change out the switch there cheap
If the curtain is hanging open the machine should just shut off as if it were full. Two blinks, in my experience is:
1) Ice thickness control either set too thin, dirty, or malfunctioning
2) Bin switch malfunction
3) Water leak, or bad fill, causing ice to be too thin to harvest
4) Compressor shutting off during cycle
5) Water pump failure
6) Water curtain not aligned right.
You can't trust the blinks completely. Many times a long harvest just happens to coincide with very slow ice production. It depends on when in the cycle the problem develops.
The probe is set for 3/16" off the evap, to get you a 1/8" ice bridge
