I am working on helping to advise (_not_ diy) an owner of a well constructed house in Iowa and need more info on the topic of properly suppling make up air. This modern, well insulated house is undergoing weatherization to attempt to eliminate maximum air infiltration and will soon have duct blaster and blower door testing to confirm that pretty much all measures have been taken to seal it. Measures include new windows, duct sealing with HVAC mastic, seal any/all holes & cracks in attic and basement, foam seals behind all light switch/outlet plates plus weather strip the exterior doors.
This one story house (with full basement) has an electric clothes dryer, kitchen exhaust fan, two bathroom exhaust fans, one natural gas, passive vented water heater (tank) and a two year old, natural gas, forced air, Trane condensing furnace. The furnace has a pass through humidifier added. Radon testing will happen soon.
I want to understand best practices for properly providing make up air, air balance, fresh air circulation, etc.
First priority appears to be: Accommodate the existing exhausting devices to avoid any sort of natural gas backdraft (?) - avoiding negative pressurization and achieving an optimal air pressure balance.
Next priority appears to be: Assure the proper number of fresh air changes are taking place per hour/day.
Finally, I want to assure that as much energy is being conserved as possible while keeping a safe and healthy house.
I ~think~ the best approach is to add a Heat Recovery Ventilator to the system and link it to the furnace blower. But given the two blowers in the HRV, I wonder if it will balance the pressure effectively. Do I need something more ... um ... passive?
Budget is not the highest priority but I want to make sure the selected HVAC contractor does not over engineer the system either. _Thanks for adding your advice and warnings._
Note: I am a newbie here @ HVAC-Talk and still learning to search this amazing knowledge base. I apologies in advance if my question has been throughly covered in an existing thread. I am still searching but for now, I am all ears!
