This is my first experience with a pool dome. We have a new customer with a Commercial Pool dome. It's over 30yrs old, and many of the mechanical pressure relief dampers no longer work. It's sort of a mess. Anyway customer says main unit never had any issues maintaining 1.25" until this year. Now the backup is constantly kicking in, and it must be the motor is what they insist. The motor is fine. It pulls 17.5A with 203V at the static pictured. It's 3yrs old, but not by us. The wheels maybe dropping a few a CFM due to age, but if you can't maintain static It's going somewhere! They have all pressure relief dampers closed. I honestly think they have leaks in the dome they refuse to address.
I know how it is with fans and blowers. My question is about affinity laws for static pressure with this motor. I noticed that if you open a door of the dome Static pressure goes down, the amps go up. Is that equivalent to no work? Shouldn't it work harder too bring the dome back up? What I am asking is could a leak in the dome cause higher amps, and if the dome was tight and sealed, and pressure reliefs working as they should amps would stay down due to correct design load on motor.
I have also never thought of 100% outside air with those laws. I have always thought of them as having a return ducted in.
Motor pulley is 7"
Shaft Pully 14"
Distance apart is 36.5"
None of that has been changed from what I know of, and only thing I know that has been changed are motors, and 4yrs ago they got a new dome. Customer states they have no design specs, so who knows. I just want to better understand the affinity laws of this type setup, so I can confirm my Job is correct. We don't do the dome at all!
Any help is much appreciated! Thanks guys!
Motor pulley is 7"
Shaft Pully 14"
