I am designing and planning to install a Lochinvar Knight WH085 boiler. The I/O manual indicates a option utilizing a low voltage output signal (BLR PUMP OUTPUT: Boiler pump speed output),it is wired to, and used to control the speed of a variable speed boiler circulator. Page 37 indicates that a (delta T) can be set to control the flow of the boiler pump.
The Service manual states the speed of the boiler pump can be controlled by the SMART SYSTEM control in order to maintain a minimum Delta T through the heat exchanger. Thus, as the firing rate decreases, the speed of the boiler pump can decrease as well. The SMART SYSTEM control outputs a 0 - 10V signal to the boiler pump to control its speed. The Boiler Pump Minimum Voltage parameter determines the minimum voltage given to the boiler pump, thereby setting its minimum speed. The range of this setting is 2.5V to 10V. The default setting is 3.5V.
I would like to implement a variable speed boiler pump. My goal would be to use the programmable features of the SMART system to define a Delta T to maintain. Basically I want to do the same thing a “Taco Delta T “circulator does, but have the Delta T programmable rather than fixed, taking advantage of the input and output sensors that already exist in the boiler. I can’t find any way to program a delta T parameter. Possibly the BLR PUMP OUTPUT is just a signal that’s value is directly proportional to the modulated fan speed. I don’t know. Can someone give me more detail on how this BLR PUMP OUTPUT is controlled?
