1 - 1 of 38 Posts
Some thoughts:
- It's not possible to charge a mini-split correctly by simply looking at gauges or guessing. Charges have to be weighed in with an amount calculated by measuring the lines, etc. These are critical charge systems - it doesn't take much either way to cause a problem.
- It's a violation of the Clean Air Act to knowingly "dump" refrigerant out of system. Even "ozone friendly" gasses like R410A have to be recovered and disposed of properly.
- The correct fix for you is to recover the system, pull another vacuum, and weigh in the correct charge. Period.
Save
1 - 1 of 38 Posts
