we have an older lennox G8 gas furnace/ac system. our problem is whether you are running the ac or the furnace, it kicks on and runs normally for the first cycle. after that when it tries to kick in again after the thermostat tells it to, it won't run the blower. It acts like it is trying to and the motor won't hardly turn, even by helping it. motor blower does turn very easily when not hot. It will continue to try to keep kicking in even after turning the thermostat setting to off. You can only get it to stop by pulling the disconnecting the power at the panel. If you let it completely cool down for about thirty minutes it will then kick in and run normal.. For ONE cycle and then you have to turn it offf at the thermostat so that it does not try to kick on again. Wait thirty minutes and turn it back on. I am guessing the capacitor??? or that other little box/ controller???? Not familiar with this type of motor. No starter?????
