Hello,
I have found that the Testo 316-4 leak detector is the most sensitive refrigerant leak detector for r410a. It has found leaks that haven’t been found by the dtek stratus, fieldpiece dr58 and a few other leak detectors I’ve bought and sold. I have tested a lot of leak detector too.
The testo has alerted r410a leaks just by walking into a home with the system running. I have yet to find a better leak detector for R410a. The H10 is also a great leak detector but is not as easy to use in tight spaces that you have limited access to the equipment. I also use the testo 316-3 for locating r22 leaks.
I’ve also had some good success locating leaks with my ultrasonic leak detectors. I could actually hear a refrigerant leak from 20ft away on a York microchannel coil condenser. The ultrasonic leak detector is usually my last resort when trying locating a small leak before I break down a inject some spectroline UV dye into a system, if allowed….i know many people don’t like UV dye but find it come in very useful in some situations.
Cheers
