1 - 5 of 17 Posts
zmanvortex
· Professional Member*
Joined
Discussion starter · #1 ·
Discussion starter · #3 ·
Thanks numbawunfela. I still don't see how that sideloop would change how the reheat valve and damper would sequence? I don't think it utilizes a DAT SP point in the sequence.
Discussion starter · #5 ·
I don't see that there is an ability to modify the "canned" program. The controller is only "configurable" through check boxes using HVAC Pro software. I don't have the software or controller in front of me so my question was to whether there was an option (check box) in HVAC Pro to configure that particular controller to sequence to discharge air for single duct VAV w/reheat. All of the documentation I found doesn't really answer that question for me. Thanks for the hints numbawunfela!
Discussion starter · #14 ·
Yes, LCT is most definitely the easiest way to do it, especially if you are only talking about a few VMA's. The HVACpro logic CAN be changed though; as in new questions, answers and IOs. I have been doing it for a few years now. If you have several hundred or even several thousand VMAs and not enough space in your NAE then it may be worth the effort.
Ok, now you have my curiosity going full tilt. What tool do you use to create these new questions, answers and IOs? How do you tie these new questions, answers, and IOs to new logic in the controller?
1 - 5 of 17 Posts
