1 - 1 of 4 Posts
If the N2 trunk is on the older NCM, you would use GPL (Graphic Programming Language) or JCB (Johnson Controls Basic) to build a control object to control your exhaust fan.
If the N2 trunk is on the newer NAE, you add an Interlock object. Select a folder under programming and Insert - Object - Interlock. It is pretty straight forward.
1 - 1 of 4 Posts
