1 - 7 of 7 Posts
dapper
· Professional Member
Joined
Discussion starter · #1 ·
Weather service brings in all 'Forecast' values but all 'Current' values are stale. Any ideas?
Save
The NWS data comes from 3 separate servers:
graphical.weather.gov [forecast]
www.weather.gov gets [current conditions]
alerts.weather.gov gets [advisories]
Take a look at the property sheet of your provider:
slot:/Services/WeatherService/WeatherReport/provider|view:workbench:propertySheet
Look at your station id and see if you can get the data directly from their site:
For example:
http://w1.weather.gov/xml/current_obs/KSAN.xml
Replace KSAN with your station id.
Discussion starter · #3 ·
Thanks digo. I tried the two local IDs in a browser, they work fine. I have other Jace sites using the same services with no problems.
This is what I found in Application Director;
WARNING [12:48:55 16-Sep-13 EDT][weather] Redirect to http://w1.weather.gov/xml/current_obs/KROC.xml
WARNING [12:48:55 16-Sep-13 EDT][weather] Updating current conditions failed for Rochester
javax.baja.sys.BajaException: 403 Forbidden
and this doesn't look right to me;
Caused by: java.lang.Exception: www.weather.govhttp://w1.weather.gov/xml/current_obs/KROC.xml
I tried to reload the weather.jar file but nothing changes. Could the file be corrupt?
Save
It's possible. Take a look at the slot sheet for the provider. You can clear the hidden flag on the conditions server and conditions path, then verify they are set as such:
www.weather.gov
/xml/current_obs/
what version of the weather module do you have?
1 - 7 of 7 Posts
