hello
I recently had a problem with my Sequencer arcing from a connection, i had someone come in and redo that connection for me and the Arcing stopped, now i noticed that on the relays to the elements theres a very small arc when the elements energize and heat is that normal ?? There is all so very small arcs that happen in side of the center double stacked relay on the sequencer, it sparks about 3 times on start up and stops, is that normal ?? the relay that had the arc problem was the bottom one,this is the center one that has the small arcs inside, They don't spark all the time just sometimes and the center one on start up always does it for about 2 sec. any help would be appreciated, i just want to be safe with the winter temps hitting -3 to -7 degrees this year. :gah:
