I did some research on the dehumidifier. In Chicago, it is most likely not necessary. Our winter here is usually too dry; it doesn't feel very humid inside in the summer either, mostly because of the AC. So I think I still want to install the ERV.
Here is what really happens with simple fresh air ventilation
Introducing a fresh air change of 3-4 hours of ventilation(100 cfm) would reduce the radon by pressurizing the home, purge indoor pollutants including radon, and renew oxygen. Within a couple of hours, the home will become the same dew point as outside plus the moisture the occupants add. Radon level infiltration declines because of pressurization and air change. Wind and stack effect will increase natural infiltration/exfiltration, more drying or wetting depending on outside weather.
Let us start with your home in mid day in summer heat 85^F, 51% RH, 65F dew point. with the a/c maintaining 75^F, 50%RH, a 55^F dew point. assuming the a/c is setup ideally. Your a/c is removing 3 lbs. of moisture per ton per hour of run. Your a/c will maintain <50%RH when it runs more than 50% of the hour. Evenings and rainy days the a/c will not maintain 50%RH. You need 2-5 lbs. of dehumidification per hour to maintain <50%RH with normal chicago mild season dew points. You need 2-3 lbs per hour of humidification during outdoor 10-35^F winter with natural stack/wind natural infiltration in typical homes.
The ERV does the following.
You activate the ERV and a fresh air change occurs in 3-4 hour, roughly 100 cfm of fresh air. The ERV exhaust and intakes 100 cfm. Exhausting and intakes pass each other through the heat/moisture exchanger. The two air stream transfers a small portion of heat/moisture
from damp to dry/warm to coo air stream.
The ERV will not control or reduce the indoor %RH but only reduce the overall effect. During the many conditions, full humidification and dehumidification is needed to maintain indoor conditions.
Also your home needs make-up air for the clothes drier, gas water heater, kitchen exhaust, and bath fans to operate. ERVs good for applications in extreme heat/cold, wet/dry, large air flow conditions.
A small whole house dehumidifier with the fresh air ventilation (Merv 13) is the best solution to this problem in most green grass climates.
Your choice. Monitor your homes indoor %RH and CO2 levels to watch the effect of weather on your home to test my statements. I have sold thousands of HRVs/ERVs through the energy crunch of 80s. They good in the right application. But you will need supplemental dehumidification to maintain 50%RH with a good ERV on your home.
Keep us posted on whatever you do. I share your concern about your indoor air quality.
Regards Teddy Bear
