Installed a nest thermostat recently, but there is no wire that resembles a connection to the humidifier. Is it possible that the humidifier is just set to run when the heat is on? It hasn't turned on since I've installed the Nest...
:This is off their website:
The 3rd generation Nest Learning Thermostat can control:
Heating: up to three stages
Cooling: up to two stages
Heat pumps with auxiliary and emergency heat
Fans
Humidifiers
Dehumidifiers
So then the OP should contact NEST tech support.This is off their website:
Fans
Humidifiers
Dehumidifiers
