How many pounds of r410a, can you put in a 30lb mastercool tank? and how many pounds of r22, can you put in a 50 pound mastercool tank? .... safely (total weight, including tare weight?) Thanks Gary
so if its a 50lb tank, i take 80% which is 40lb, and then add the tare weight? 28.71lb so 68.71lb total weight? and on the 30lb, 24lb+ tare 17.99lb, so 47.99 total weight, is that right? (what i do now is fill the 30lb close to 30lb, and the 50lb close to 50lb)
Your tank should have a WC stamped on it (water capacity, I believe). For Example a 30lb tank will have something like "WC 24.8". Your refrigerant capacity is 80% of the WC weight.
how does a 80% shut off work (i dont have one on my stinger thats why i ask) but wouldn't that go by pressure? and pressure increases with temp, dif with dif refrig, so thats why im confused, i know the 80% is to deal with temp fluctuations causing higher pressure right?
You can only fill a recover cylinder to 80% of its capacity by VOLUME. As stated recovery cylinders have their water capacity stamped in it.. They use water as a reference as its density is consistent at room temp 62.4lb/cubic foot..
With this number you can figure out the volume of the cylinder you have.. As an example lets say you have a recovery cylinder with a water capacity of 25 lbs( just a number I picked out if my head)
The internal volume of the cylinder is
D=m/v
D is 62.4 lbs/cubic foot
M= 25
V=?
Solving for volume
V d= m
v= m/d
V= 25/62.4
V= .401 cubic feet
Then using the density of the refrigerant you are recovering at 70deg f let's say its R-22 @72.57 lbs/ cubic ft
D=m/v
M=(d)(v)
M= (72.57)(.401)
M= 29.07 @ 100% full
When it starts taking too long to recover, turn the tank in for an empty. That's likely the reason no one ever had a problem with a burst recovery tank as they would have long since been fed up with the recovery times...
The difference in volume is also why you see some refrigerants sold as 30 lb tanks and some as 25 lb tanks. They use the same size tanks but there are different specific volumes of the refrigerants so they have to compensate. FYI
In the Pro Forum Training and Education dated 3-19-2010 Rundawg posted a chart showing both gross weight and net weight for most refrigerants and for several sizes of recovery cylinders. Search" Recovery Tank Capacity"
It is 80% by volume. It's simple to figure out for each refrigerant.. All you need is the density if the refrigerant.. No need to reinvent the wheel here!
Related Threads
HVAC-Talk: Heating, Air & Refrigeration Discussion
