Is there a way I can use two remote indoor sensors and average them or do I have to do four indoor sensors?
I don't believe the TH can do what the TB can do. I could be wrong though.Yes you can
I will play with them again today, both the 10k and 20k sensors, and see if there is any problem.I don't believe the TH can do what the TB can do. I could be wrong though.
Have you ever tried using 2 sensors on a TH.
Thanks BT. In the installer manual for the TB it shows that the indoor sensor can be either 20K or 10K (installer code 0340 setting 3 for 10K and setting 4 for 20K). Does that not mean the TB can use either sensor in a single remote configuration? If so I just wondered what differences there are between the two?The TB uses a 20K for single remote sensor applications.
And the TH uses a 10K for single remote sensor applications.
The TB uses 2 10K's to average 2 sensors. So you would need 2 5K's with the TH to average 2 sensors(don't think you'll find 5Ks).
Yes, that is the way I understood it too. But, why would someone choose one sensor over the other to use with the TB. My thought was the 20k may be more sensitive to temp changes and thus it responded a little faster.The TB can use either.
The TH can't. Only 10K's.
That's what I thought. Thanks for confirming.A 20K is more sensitive/accurate. In that its resistance changes more per degree of temp difference.
But the stat doesn't control temp any different.
I think its a left over from/for lon communications. Since the TB may be replacing a small lon system. It can use the same 20K sensors. Or a lon systemcan be installed in place of the TB and use the 20K sensors.
OK here is how I used only two sensors.
I disassembled 2 10ks and then installed 2 into one in one location, thereby not having to have them spread across some walls (residential).
That is the beauty of the IAQ stat in that you can install one sensor and do temp averaging. The IAQ's stats sensor is used where as the TH 8's aren't in an averaging network.
Hmmm.
The TB install instructions says it doesn't use the on-board sensor for averaging. Just the remotes.
This was in reference to the "th"
not "tb"
