1 - 1 of 10 Posts
Why wouldn't Contractor 3 bid a matching Amana Air Handler instead of retrofitting a new coil in a old air handler and heater elements? To me that would be more of a professional grade Contractor. Also no mention of the labor warranties these companies are offering. Isn't a strong labor warranty important to you? I can see why this company is the cheapest so far. In regards to your limited exposed existing line set, make sure there is no soft solder joints as they may leak when reused with the higher refrigerant pressures of R410A. Hopefully there is no soft solder connections behind the finished ceiling of your existing line set.
Save
1 - 1 of 10 Posts
