I want to make sure that I do this right before I commit to this system.
I'm concerned about the coil that's listed on my contract. It's copper but not tin plated (Carrier 3.5 Ton Performance Series Cased N-Coil. Puron Model CNPHP4221). My rep said that the tin plated is only used for high humidity areas (which I'm not in). Is this true? Should I spend more money and special order one or am I okay with this one?
Under programmable thermostat, it's listed as a Carrier PS701...is this okay or should I ask for a Honeywell, and if so, which one?
When do they show you the Manual J/D...before you sign the contract or after?
My proposed system is a:
Carrier Infinity Series Variable Speed Furnace Model #58CVX-090116.
Carrier 3.5 Ton Performance Series Condensing Unit Model 24APA542
I need to get this A/C in ASAP. We're currently without anything and are approaching 100 degree plus weather.
