Purchased and installed brand new electric furnace in my home. (Winchester model WMA 48-12)
I am getting a flash code of "multiple limit openings during one call for heat". Was told this was an overheat issue. Once temperature is reached according to thermostat, the heat coils will shut off but the fan constantly runs.
Since then I have added a vent on my return air duct as well as added a vent in the basement. Still same problem
If I take out jumper wire to run only half of the coils, the furnace runs and shuts off OK but is not sufficient enough to keep the house warm.
With the jumper wire installed I can see entire coil cycle on and off every 15-20 seconds producing great heat while on.
What do I need to do in order to run this furnace properly?
