Hello,
I recently bought a Home that was built in 1999 last September, and the Heat Pump is the same age of the home (15 yr). The original owners seemed to never use the Heat Pump much as the lockout temperature was setup pretty high around 50 degrees. However, with the cost of LP these days I want to run more of the heat pump rather than spend $ on fuel. So after spending last winter playing around with settings, I found that the sweet spot for cost and comfort for my unit is around 33-35 degrees. So I have the dip switches set to around that temperature.
My question and maybe somebody could explain. What I have noticed is that sometimes while the heat pump is running and icing up, instead of running a defrost cycle it will shut off and the switch to the furnace.
Here is an example of what happened this morning. It was around 33 degrees out, the heat pump kick on and ran for 45 minutes and looking pretty icy but then it shut off, and furnace kicked on. I turn the thermostat down and let everything sit for 15 minutes.
Then I turned the thermostat back up. The heat pump kick on and run for another 15 minute and then when through a defrost cycle. Why is doing this behavior? Does this have something to do with getting a false reading for the temperature sensor in the compressor, and making it think it’s colder than it really is outside? Is this just downfall of unites configured this way, in that on days when temperature is on the low end of it's configured lockout might switch over to furnaces when it gets icy.
My Setup: System is 15 years old
HEIL DC 90 Hybrid System (Heat Pump with a LP Furnace)
The system is configured with a dual fuel control module (with outside thermostat in the compressor) and the control board has the temperature lockout control on it.
I did have the unit serviced and inspected last spring by a HVAC tech, and it was given a clean bill of health.
